Cant issue certificate for domain
My domain is: 202-za.resrequest.net
I ran this command:sudo certbot --apache
certbot type: unauthorized detail: invalid response from apache
apache 2.4.18
Ubuntu 16.04
(Local hosting in South Africa : Hetzner)
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.26.1
I have checked that no AAAA record is setup for the domain
What does this show?
apachectl -t -D DUMP_VHOSTS
Could you please include the full output of the command? Thanks!
blank to select all options shown (Enter ‘c’ to cancel): 1
http-01 challenge for 202-za.resrequest.net
Waiting for verification…
Failed authorization procedure. 202-za.resrequest.net (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://202-za.resrequest.net/.well-known/acme-challenge/f1V4IRaY7CipBS6fKpnhBRcPbmv7Ayh0qnq6endcMEI: “\n\n404 Not Found\n\n
Not Found
\n<p”
Thanks, that looks fine. In case it got lost:
In cases like these, it's common for ServerName/ServerAlias duplication to cause this problem, and the above can help diagnose it.
Thanks so much for your help. It seems i forgot that 0000-default.conf uses the server name setup in the config file.
Thanks again!
Any idea why the certificate is not trusted? I just issues it, on the same server i run certificates for another domain working fine.
This one now shows that it issues the certificate itself? Instead of by Letsencrypt like my other certificates
Did Certbot report success in installing the certificate?
If it did, then the cause is probably the same - some duplication in the port 443 virtual host ServerNames.
Ofcourse… the default ssl vhost (facepalm)
