Hi, to test how far I get in this certbot procedure I tried to set up SSL for a Vserver at 82.165.187.242 serving the domain www.comedyberlin.net ... and I couldnt get far. Any help appreciated! Seems like I have to open port 80 for certbot to do its thing, but I have no idea how to do so. I have a little node js server running on port 80 though, does it mean I would have to set up some path there for certbot to get the files it demands?
Thanks for your help!
It might even be right but the webserver is only listening on IPv4? (And doesn't like me)
# curl -4IL comedyberlin.net
curl: (7) Failed to connect to comedyberlin.net port 80 after 35 ms: Connection refused
# curl -6IL comedyberlin.net
curl: (7) Couldn't connect to server
# curl -4IL www.comedyberlin.net
curl: (6) Could not resolve host: www.comedyberlin.net
# curl -4IL https://comedyberlin.net
curl: (7) Failed to connect to comedyberlin.net port 443 after 9 ms: Connection refused
# curl -6IL https://comedyberlin.net
% whois 2001:8d8:100f:f000::23f
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: this output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '2001:8d8:1000::/44'
% Abuse contact for '2001:8d8:1000::/44' is 'abuse@oneandone.net'
inet6num: 2001:8d8:1000::/44
netname: IONOS-NETWORK
descr: 1&1 IONOS SE
country: EU
org: ORG-SA12-RIPE
admin-c: IPAD-RIPE
tech-c: IPOP-RIPE
remarks: in case of abuse or spam, please mailto: abuse@oneandone.net
status: AGGREGATED-BY-LIR
assignment-size: 56
mnt-by: AS8560-MNT
created: 2012-08-29T10:47:33Z
last-modified: 2020-11-27T17:15:36Z
source: RIPE # Filtered
organisation: ORG-SA12-RIPE
org-name: IONOS SE
country: DE
org-type: LIR
address: Hinterm Hauptbahnhof 5
address: 76137
address: Karlsruhe
address: GERMANY
phone: +49 721 91374 0
fax-no: +49 721 91374 212
mnt-ref: RIPE-NCC-HM-MNT
mnt-ref: AS8560-MNT
mnt-by: RIPE-NCC-HM-MNT
mnt-by: AS8560-MNT
admin-c: IPAD-RIPE
abuse-c: ABDE2-RIPE
created: 2004-04-17T11:11:55Z
last-modified: 2021-08-05T05:33:57Z
role: IP Administration
address: 1&1 IONOS SE
admin-c: JR2342-RIPE
admin-c: SH15342-RIPE
tech-c: JR2342-RIPE
tech-c: SH15342-RIPE
nic-hdl: IPAD-RIPE
abuse-mailbox: abuse@oneandone.net
mnt-by: AS8560-MNT
created: 2009-05-20T17:24:09Z
last-modified: 2020-11-27T12:38:59Z
role: IP Operations
tech-c: JR2342-RIPE
nic-hdl: IPOP-RIPE
mnt-by: AS8560-MNT
created: 2009-05-28T16:25:04Z
last-modified: 2020-11-27T12:40:30Z
% Information related to '2001:8d8::/32AS8560'
route6: 2001:8d8::/32
descr: DE-IONOS-20020910
origin: AS8560
mnt-by: AS8560-MNT
created: 2006-08-03T11:11:31Z
last-modified: 2020-11-27T18:41:31Z
% This query was served by the RIPE Database Query Service version 1.102.3 (BLAARKOP)
I only added the server at the A record. For the other one (AAAA record) IONOS used their own? Unfortunately I cannot add the 82. ... address there since Ipv6 is required.. how can I go from here?
If you've removed the AAAA resource record, the error should be different this time. Well, idealy no error at all, but we'd like to see what you're getting now.
