No valid IP addresses found for my domain
I'm facing issues in generating Letsencrypt SSL certificates for a domain mapped to a private address. (192.168.19.15)
My domain is: elk.internal.mindcurv.com and its a public domain (Verified from DNS Checker - DNS Check Propagation Tool)
jerald@jeraldsm:~$ nslookup elk.internal.mindcurv.com
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 192.168.19.15
I ran this command for generating SSL certificate:
./letsencrypt-auto certonly --standalone -d elk.internal.mindcurv.com
It produced the following output:
[root@elk-slreport letsencrypt]# ./letsencrypt-auto certonly --standalone -d elk.internal.mindcurv.com
http-01 challenge for elk.internal.mindcurv.com
Challenge failed for domain elk.internal.mindcurv.com
I have also tried using the command "cerbot --apache". This one also failed with similar error:
[root@elk-slreport ~]# certbot --apache
1: elk.internal.mindcurv.com
The operating system my web server runs on is (include version): CentOS Linux release 7.7.1908 (Core)
My hosting provider, if applicable, is: Apache/2.4.6
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.39.0
Is it possible to issue a certificate for private IP address ?
Thanks in advance!.
This isn't going to be possible without using DNS validation to obtain the cert.
As an alternative, if you like split-horizon DNS, you could potentially set something up where elk.internal.mindcurv.com has a routable IP in the external view. E.g. the machine’s own IP, or another machine running a reverse proxy web server…
I’m not endorsing it, just saying you have options. Increasingly complicated and customized options.
