Need some help with error message
My domain is:nc.champion-cloud.com
I ran this command: sudo certbot --apache --agree-tos --redirect --staple-ocsp --email admin@champion-cloud.com -d nc.champion-cloud.com
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for nc.champion-cloud.com
Challenge failed for domain nc.champion-cloud.com
My hosting provider, if applicable, is: namecheap
I can login to a root shell on my machine (yes or no, or I don't know):i dont know
This error is happening because your domain points to a private IP address (192.168.1.105).
In order to issue you a certificate, Let's Encrypt needs to be able to connect to your domain name, to check that you really control this domain.
Since the IP address is part of a private local network, Let's Encrypt can't connect to it. That's what the error is about.
If you want people outside of your local network to be able to connect to your website, you will need to use the public IP address that your ISP gives you, and also to setup port forwarding on your router so that ports 80 and 443 get routed to your webserver.
If you want to continue keeping the website private to your local network, you might be able to acquire a certificate using the DNS challenge, but it can be a bit tricky to do so with Namecheap.
