My domain is: garagum.xyz
I ran this command: acme.sh --issue -d garagum.xyz -w /home/wwwroot/garagum.xyz
It produced this output: garagum.xyz:Verify error:No valid IP addresses found for garagum.xyz
I want to use my domain for v2ray trough cloudflare.com/. I have garagum.xyz on dynadot.com.
I changed name servers to NM’s I got from CF. I run my VM on Google Cloud Console.
As I understand there is an issue with ip’s. But which IP’s I should use?
Thanks
9peppe
2
Log into their panel, and add appropriate A records for the machines you want.
Hi @igaresh
there are some checks of your domain, created yesterday - garagum.xyz - Make your website better - DNS, redirects, mixed content, certificates
eugene.ns.cloudflare.com is one of your name servers.
There you have to add the missing
| Host |
T |
IP-Address |
is auth. |
∑ Queries |
∑ Timeout |
| garagum.xyz |
A |
yes |
1 |
0 |
AAAA |
yes |
| www.garagum.xyz |
Name Error |
yes |
1 |
0 |
A- or AAAA- entries.
Thanks
Yes, I’ve checked it yesterday. Since I’m doing it for the first time I’m a bit confused.
Where should I add it: dynadot or cloudfare? And what should I add: my server IP or domain?
9peppe
6
cloudflare:
% dig garagum.xyz ns
; <<>> DiG 9.16.1-Ubuntu <<>> garagum.xyz ns
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 10686
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;garagum.xyz. IN NS
;; ANSWER SECTION:
garagum.xyz. 86399 IN NS eugene.ns.cloudflare.com.
garagum.xyz. 86399 IN NS natasha.ns.cloudflare.com.
;; Query time: 135 msec
;; SERVER: 127.0.0.53#53(127.0.0.53)
;; WHEN: mer apr 22 11:39:24 CEST 2020
;; MSG SIZE rcvd: 100
Thanks a lot @9peppe and @JuergenAuer
Fixed
