Issue when dns hosting on cloudfare
Domain: educatemn.org
Detail: Invalid response from
http://educatemn.org/.well-known/acme-challenge/3CwR-ITagmVEhUfQlQGLeTcQ3N8IkN3wSl97ZqXlNLw
[3.14.21.94]: 404
FATAL: all hosts have already failed – aborting
The operating system my web server runs on is (include version): linux
My hosting provider, if applicable, is: cloudfare
I updated the A record to β€˜3.14.21.94’ still https://check-your-website.server-daten.de/?q=ercmn.org shows β€˜104.27.158.61’ and hence it seems certbot is failing. Can you please help?
Thank You.
Hi @Pankti
where did you update that record? Now I see the 104.* address. But Letsencrypt has seen the 3.14.*
There is no older Letsencrypt certificate listed, the CT-part shows only the
CloudFlare Inc ECC CA-2 2019-05-22 2020-05-23 *.ercmn.org, ercmn.org, sni.cloudflaressl.com
3 entries
Cloudflare Certificate.
Looks like you use the integrated Cloudflare solution to have a SSL connection between your server and Cloudflare. Then you don't need an own Letsencrypt certificate.
Checking your raw ip there is another certificate - https://check-your-website.server-daten.de/?q=3.14.21.94
CN=careerleaf.com
	28.08.2019
	26.11.2019
expires in 18 days	*.careerleaf.com, careerleaf.com - 2 entries
PS: Oh, there are some different informations.
There you use
ercmn.org, not the educatemn.org.
There is a check of the educatemn.org - https://check-your-website.server-daten.de/?q=educatemn.org
That domain has the 3.14.* ip address. But there is the error:
β€’ http://educatemn.org/ 3.14.21.94 GZip used - 56 / 36 - -55,56 % 404 Html is minified: 100,00 % 0.267 M
NOT FOUND
β€’ https://educatemn.org/ 3.14.21.94 GZip used - 56 / 36 - -55,56 % Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 404 Html is minified: 100,00 % 4.094 N
NOT FOUND
Certificate error: RemoteCertificateNameMismatch
β€’ http://educatemn.org/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 3.14.21.94 GZip used - 56 / 36 - -55,56 % Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 404 Html is minified: 100,00 % 0.266 A
NOT FOUND
Visible Content: domain is not defined: educatemn.org
Domain is not defined.
Looks like your vHost setup is incomplete.
What command did you run? What was the complete output? What ACME client are you using? What version of it?
Hi there,
There was an error with dns records. www routing was also added as an β€˜A’ record and hence error. Removing it solved the issue.
Thank you guys for your apt response. Really appreciate it.
Thanks.
That's possible.
But if you have a main domain, it's better to have a DNS entry and a correct configured vHost with one certificate and both domain names. And correct redirects.
Some users add always www to the domain name.
