My domain is: mtg.perpetum-mobile.ru
I ran this command: sudo certbot certonly
1: Nginx Web Server plugin (nginx)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): mtg.perpetum-mobile.ru
Requesting a certificate for mtg.perpetum-mobile.ru
Domain: mtg.perpetum-mobile.ru
Type: dns
Detail: During secondary validation: DNS problem: NXDOMAIN looking up A for mtg.perpetum-mobile.ru - check that a DNS record exists for this domain; no valid AAAA records found for mtg.perpetum-mobile.ru
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Ubuntu 20.04 LTS
My hosting provider, if applicable, is: fornex
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.26.0
