Dns and AAAA record issue
My domain is: playpalindia.org
I ran this command: not able to install ssl certificate
It produced this output: domain not found Dns and AAAA record issue
Google Cloud debain server
Hi @chandresh
what client did you used?
Your domain has an ipv4 address:
playpalindia.org A 35.241.93.249 yes 1 0
AAAA yes
www.playpalindia.org A 35.241.93.249 yes 1 0
AAAA yes
and your port 80 is open and answers with a correct http status 404 / not found checking a file in /.well-known/acme-challenge.
And there is an older cPanel certificate:
CRT-Id Issuer not before not after Domain names LE-Duplicate next LE
1172379472 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-02-03 02:50:52 2019-05-04 01:50:52 webmail.playpalindia.org
948490275 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2018-11-15 09:12:27 2019-02-13 09:12:27 webmail.playpalindia.org
913807932 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2018-11-03 02:42:43 2019-02-01 02:42:43 cpanel.playpalindia.org, mail.playpalindia.org, mail.playpalindia.org.cp-in-17.bigrockservers.com, playpalindia.org.cp-in-17.bigrockservers.com, webdisk.playpalindia.org, webmail.playpalindia.org, www.playpalindia.org.cp-in-17.bigrockservers.com
Thanks for your email
I have installed ssl certificate for domain lavacast.in using google cloud server after installation my website stopped working. I have already restarted apache.
sudo a2ensite default-ssl
sudo a2enmod ssl
sudo service apache2 restart
Warm Regards,
Chandresh Suvarna
Assistant Manager - IT
SAL-mumbai
SETCO AUTOMOTIVE LIMITED
2 / A, Ground Floor,
Film Centre Building, 68 Tardeo Road, Tardeo,
Mumbai - 400034
India
(O)+ 91(0)22 40755555
(F) + 91(0)22 23520754
(D)+ 91(0)22 40755541
www.setcoauto.com
www.setcofoundation.org
DP Every 3000 sheets of paper cost us a tree. Let’s conserve.
There is a new Letsencrypt certificate:
1374233140 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-11 03:07:11 2019-07-10 03:07:11 lavacast.in, www.lavacast.in duplicate nr. 1
But it's your first certificate, so your https configuration may be incomplete.
Your port 80 works, port 443 doesn't.
• http://lavacast.in/
35.200.150.140 301 https://www.lavacast.in/ 0.727 E
• http://www.lavacast.in/
35.200.150.140 301 https://www.lavacast.in/ 0.727 A
• https://lavacast.in/
35.200.150.140 -14 10.027 T
Timeout - The operation has timed out
• https://www.lavacast.in/
35.200.150.140 -14 10.024 T
Is there a firewall? Or is there a new port forwarding required?
Checking your ip ( https://check-your-website.server-daten.de/?q=35.200.150.140 ) there is the same timeout.
• http://lavacast.in/ 301 https://www.lavacast.in/ 0.883 E
• http://35.200.150.140/
35.200.150.140 301 http://lavacast.in/ 5.120 D
• https://35.200.150.140/
35.200.150.140 -14 10.030 T
• https://www.lavacast.in/ -14 10.027 T
I am new to this. Kindly help with solution
Thanks,
Chandresh Suvarna
Thanks for your quick response I did changes on server and it issue resolved.
Warm Regards,
Chandresh Suvarna
SAL-mumbai
Mumbai - 400034
India
www.setcoauto.com
Yep, now you have a new certificate:
CN=lavacast.in
	11.04.2019
	10.07.2019
expires in 90 days
lavacast.in, www.lavacast.in - 2 entries
So both connections are secure.
But you have some http images -> mixed content.
Sample:
http://lavacast.in/wp-content/uploads/2018/01/lavacastcertified.png
Perhaps you should change that.
Thanks a lot sir.
Warm Regards,
Chandresh Suvarna
SAL-mumbai
Mumbai - 400034
India
www.setcoauto.com
