No module named datetime Error when Autorenew certbot
Hi Let's Encrypt community, I need some help with auto-renewing my SSL :slight_smile:
It's been auto-renewing manually every 90 days for a while but after a server tidy up it seems to be showing some errors now and I can't debug.
https://rwwriter.com
./certbot-auto renew
Error: couldn't get currently installed version for /opt/eff.org/certbot/venv/bin/letsencrypt:
File "/opt/eff.org/certbot/venv/bin/letsencrypt", line 7, in
from certbot.main import main
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 9, in
from acme import jose
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/jose/init.py", line 37, in
from acme.jose.interfaces import JSONDeSerializable
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/jose/interfaces.py", line 9, in
from acme.jose import util
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/jose/util.py", line 5, in
import OpenSSL
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/OpenSSL/init.py", line 8, in
from OpenSSL import rand, crypto, SSL
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/OpenSSL/crypto.py", line 1, in
import datetime
ImportError: No module named datetime
Then I ran:
python -c 'import datetime; print datetime.datetime.now()'
And it prints the date:
2017-12-29 20:59:01.267586
So it's not a Python thing..
So I tried this:
I moved the let's encrypt folder to let'sencrypt.bak and ran AUTORENEW again and same error...
Ubuntu 16.04.3 LTS
Yes
Any help greatly appreciated!!!
Cheers
What happens if you rename or delete the /opt/eff.org/certbot/ directory and run ./certbot-auto renew again? It should make certbot-auto reinstall itself and could fix this.
Thanks @mnordhoff - appreciate that
It ran and outputted this:
Reading package lists... Done
Building dependency tree
Reading state information... Done
gcc is already the newest version (4:5.3.1-1ubuntu1).
libffi-dev is already the newest version (3.2.1-4).
python is already the newest version (2.7.11-1).
python-dev is already the newest version (2.7.11-1).
augeas-lenses is already the newest version (1.4.0-0ubuntu1.1).
ca-certificates is already the newest version (20170717~16.04.1).
libaugeas0 is already the newest version (1.4.0-0ubuntu1.1).
python-virtualenv is already the newest version (15.0.1+ds-3ubuntu1).
virtualenv set to manually installed.
libssl-dev is already the newest version (1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1).
openssl is already the newest version (1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1).
The following packages were automatically installed and are no longer required:
dh-php libexporter-tiny-perl liblist-moreutils-perl libonig2 libpcre32-3
libpcrecpp0 libqdbm14 libzip4 pkg-php-tools xml2
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
Creating virtual environment...
Installing Python packages...
Installation succeeded.
No renewals were attempted.
I tried a server restart and it fails.
Nginx debugger shows:
BIO_new_file("/etc/letsencrypt/live/rwwriter.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/rwwriter.com/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
What does “./certbot-auto certificates” show?
Just checking the folder has...
It has only:
renewal-hooks
My .bak of that has:
accounts archive csr keys live renewal
So
shows:
No certs found.
I moved the certs back into letsencrypt folder and re-ran the command and boom :slight_smile:
Thanks @mnordhoff
Now to sort out the CRON :wink:
