I accidentally upgraded certbot-auto before to do renew, and it fails to renew with following error
sudo -i
  1. ./certbot-auto --version
  2. ./certbot-auto renew --debug
Error: couldn’t get currently installed version for /opt/eff.org/certbot/venv/bin/letsencrypt:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 7, in
from certbot.main import main
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/certbot/main.py”, line 10, in
import josepy as jose
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/josepy/init.py”, line 44, in
from josepy.interfaces import JSONDeSerializable
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/josepy/interfaces.py”, line 8, in
from josepy import errors, util
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/josepy/util.py”, line 4, in
import OpenSSL
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/OpenSSL/init.py”, line 8, in
from OpenSSL import crypto, SSL
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/OpenSSL/crypto.py”, line 12, in
from cryptography import x509
ImportError: No module named cryptography
nginx
amazon linux AMI
AWS
no
when I tyoe ‘./certbot-auto --version’, above error shows. But it was 0.32.0 when I upgraded accidentally before to renew the certbot-auto.
When I searched about ImportError: No module named cryptography which is the last line of the error, every body was asking about this error ImportError: No module named cryptography.hazmat.bindings.openssl.binding. But this is not the one what I got. And when I just followed the solution that people saying about ‘ImportError: No module named cryptography.hazmat.bindings.openssl.binding’ this - the solution they were talking about was /opt/eff.org/certbot/venv/local/bin/pip install cryptography - and typed ‘./certbot-auto renew --debug’ again, I got the same error as shown above.
cf) I didn’t know that this ./certbot-auto --version was upgrading itself. So my certbot-auto version was upgraded to 0.27.1 -> 0.32.0. I think this is the reason that I get the error different from others, but I can’t fix mine. Please help me. Thanks
OpenSSL is mentioned in the debug.
Which version of OpenSSL are you using?
Hi. The server’s OpenSSL version is OpenSSL 1.0.2k-fips 26 Jan 2017. And when I typed ./certbot-auto --version without sudo -i, and I received the message that
Requesting to rerun ./certbot-auto with root privileges…
Upgrading certbot-auto 0.30.0 to 0.32.0…
Replacing certbot-auto…
Error: couldn’t get currently installed version for /opt/eff.org/certbot/venv/bin/letsencrypt: (and following the same error log as above)
So it seems like my server’s certbot-auto version is 0.30.0.
You can backup the directory if you want to, but it should be safe to just completely delete the directory:
Then rerun/reinstall certbot-auto.
