Nginx - certbot renew without nginx plugin installed (python-certbot-nginx)
My domain is: https://jira.wso2telco.com/
I ran this command: certbot renew --nginx
It produced this output: could not choose appropriate plugin: The requested nginx plugin does not appear to be installed
My web server is (include version):nginx/1.4.6 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 14.04.3
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.26.1
We 've to renew the certificate which got expired yesterday, the problem is , we are unable to install nginx plugin ( sudo apt-get install python-certbot-nginx ) since we are on Ubuntu 14 as described in below article. seeking your support to renew the certificates without having nginx plugin installed.
Hello @client_x
is QUITE OUTDATED
Is there a specific reason you are running dated software?
I would consider installing an up to date version of certbot and ngix plugin from snap:
https://certbot.eff.org/lets-encrypt/ubuntuxenial-nginx
Ubuntu 14 LTS supports snaps even though the above instructions use Ubuntu 16.04 as the base OS example.
Hope this helps.
