I have tried many configuration but none is working. Somehow Nginx not accepting my HTTP requests. I have posted before about my website that SSL throwing error on mobile network and then I actually found out that this is the issue. I am trying for 3 hours but no luck.
I do not know whether it is Regional Filter or not. I ran my nginx server without cert commands and it worked fine with HTTP connections. No blocking and nothing. When I install lets encrypt SSL using cert commands then It just stops the HTTP connections although I have allowed Nginx Full in ufw
Sir you are 100% right. I checked my website with My own wifi and it redirected my to my HTTP connection properly. When I switched to a VPN it refused the connection. It is a home server and I do not know how to bypass this thing. Any advice for me sir ?
hsts preload you domain will browser to go stright to https version… but it’s totally overkill and would take too long untill deployed to browsers.
I guess you don’t have VPS available, right?
