My pleasure. I appreciate all of your help. Thanks for your valuable time.
Do you use a router?
Is the port forwarding correct?
Extern port 80 -> intern port 80?
yes this is done perfectly.
I suspect what you said is right. Cause I can access my website in HTTP from my own wifi network. But if I switch to VPN then connections are refused.
