My domain is:kjfact.communicationsystems.ca
I ran this command:certbot renew (from shell in nextcloud jail)
It produced this output:Introduction to manual pages: man man
FreeBSD directory layout: man hier
Edit /etc/motd to change this login announcement.
root@nc-new:~ # certbot renew
Processing
/usr/local/etc/letsencrypt/renewal/kjfact.communicationsystems.ca.conf
Unable to read ssl_module file; not disabling session tickets.
http-01 challenge for kjfact.communicationsystems.ca
apache24 not running? (check /var/run/httpd.pid).
Unable to restart apache using ['apachectl', 'graceful']
Encountered exception during recovery:
File "/usr/local/lib/python3.7/site-packages/certbot_apache/_internal/configurator.py", line 2419, in _reload
util.run_script(self.option("restart_cmd"))
File "/usr/local/lib/python3.7/site-packages/certbot/util.py", line 115, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apachectl graceful.
File "/usr/local/lib/python3.7/site-packages/certbot/_internal/auth_handler.py", line 70, in handle_authorizations
resps = self.auth.perform(achalls)
File "/usr/local/lib/python3.7/site-packages/certbot_apache/_internal/configurator.py", line 2516, in perform
self.restart()
File "/usr/local/lib/python3.7/site-packages/certbot_apache/_internal/configurator.py", line 2410, in restart
self._reload()
File "/usr/local/lib/python3.7/site-packages/certbot_apache/_internal/configurator.py", line 2437, in _reload
raise errors.MisconfigurationError(error)
certbot.errors.MisconfigurationError: Error while running apachectl graceful.
File "/usr/local/lib/python3.7/site-packages/certbot/_internal/error_handler.py", line 125, in _call_registered
self.funcs-1
File "/usr/local/lib/python3.7/site-packages/certbot/_internal/auth_handler.py", line 243, in _cleanup_challenges
self.auth.cleanup(achalls)
File "/usr/local/lib/python3.7/site-packages/certbot_apache/_internal/configurator.py", line 2540, in cleanup
self.restart()
self._reload()
Attempting to renew cert (kjfact.communicationsystems.ca) from /usr/local/etc/letsencrypt/renewal/kjfact.communicationsystems.ca.conf produced an unexpected error: Error while running apachectl graceful.
. Skipping.
/usr/local/etc/letsencrypt/live/kjfact.communicationsystems.ca/fullchain.pem (failure)
My web server is (include version):apache 2.4.56
The operating system my web server runs on is (include version):freebsd 13.2-Release-p9
My hosting provider, if applicable, is:self hosted
or certbot-auto --version
if you're using Certbot):certbot 1.8.0
I'm new to this. The person that normally handles these things is not available to help so it's left up to me.
The certificate, which was supposed to auto renew but it did not and my efforts at doing a manual renewal have failed dismally.
The certificate is for a Nextcloud instance that is running in a jail on a TrueNAS server. I have access to the shell of the jail and the server itself.
Any help would be greatly appreciated.
Thank you.
