My domain is:businessparksolutions.com
My web server is (include version):nginx
The operating system my web server runs on is (include version): centos7
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
or certbot-auto --version
if you’re using Certbot): certbot 0.31.0
I followed the following guide and installed nextcloud.
Then I managed to get certbot to run to get a new cert but I can`t renew it. When I am trying to do a dryrun it fails.
Here is the log
certbot renew --dry-run
Processing /etc/letsencrypt/renewal/server1.businessparksolutions.com.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for server1.businessparksolutions.com
nginx: [warn] conflicting server name “server1.businessparksolutions.com” on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name “server1.businessparksolutions.com” on 0.0.0.0:443, ignored
Waiting for verification…
Attempting to renew cert (server1.businessparksolutions.com) from /etc/letsencrypt/renewal/server1.businessparksolutions.com.conf produced an unexpected error: Failed authorization procedure. server1.businessparksolutions.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://server1.businessparksolutions.com/.well-known/acme-challenge/IV3nI7t-3KkrNvUIDnhQeBGzTBIyNrejPg816ijd058 [MY.IP.ADD.RESS]: 503. Skipping.
/etc/letsencrypt/live/server1.businessparksolutions.com/fullchain.pem (failure)
Domain: server1.businessparksolutions.com
Detail: Invalid response from
[MY.IP.ADD.RESS]: 503To fix these errors, please make sure that your domain name was
I have replaced the actual server name with server1 and also the external ip address with [MY.IP.ADD.RESS]
please advise
rajbps
