And I have several doubts / problems, the first is the / nextcloud, it is not possible to access directly via cloud.mydomain.com, second when the connection passes through the haproxy if I put cloud.mydomain.com I get to the nethserver page, but putting cloud.mydomain.com/nextcloud gives me the following error in the browser ERR_SSL_PROTOCOL_ERROR
Please if you can help me I would appreciate it, I already have everything configured and I just need to pass it through the reverse proxy / with certificate to put it into production.
Good morning JuergenAuer and thanks for your help,
At the moment it does not have a valid certificate in 443 because I expected to take it out in the HAProxy, it is pending to renew the entire HAproxy but at the moment I have several services working with this version of certbot and I have no problems, really the problem gives me when I try to access cloud .marinador.com / nextcloud, access cloud.marinador.com if you access without problems but it is not the service I want to expose, I leave the configuration of the HAproxy in case it helps …
There is no port 80 defined. So you run Certbot on the wrong machine.
You have to use the machine with that answer:
http://cloud.marinador.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
46.25.72.130
Inline-JavaScript (∑/total): 0/0 Inline-CSS (∑/total): 0/0 404
Html is minified: 100,00 % 0.140
A
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server.
And your complete command is required so your authenticator is visible.
