Newby needs help to get a certificate for redirecting
My domain is: www.pazu.de - redirection to
https://partnerschaft-fuer-die-zukunft-e-v.jimdosite.com/
My hosting provider, if applicable, is: Web-Service4U
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
I can see your website and there is no redirection, just a website hosted on ip 144.76.202.133 – that is different from the jimdo site you linked, which has a valid certificate from digicert (a wildcard for all jimdosite.com subdomains)
You need to discover how to install a certificate on your website (you currently have a self-signed, expired one).
Does your web hosting provider have any documentation about that?
Hi 9peppe,
thanks for your quick response.
As I wrote, I’m a newby to this and thought the jimdo-site would
be missing a cert.
Yes there is some handbook to be found on this link:
There is another link with some explanations: https://www.liveconfig.com/de/handbuch/tutorial.ssl.xhtml
  But it is in German (my language). Although in German I have some
problems to understand it. I am new at this provider and have to
learn a lot.
I hope to get some help from you. Thanks in advance
Regards Helmut
You should probably check if you can add the domain to jimdo directly.
I suspect that’s not available on their free plans, though.
Yes, we checked it and we can’t add our domain directly unless we buy a more costly version there.
on the support pages at web-service4U they discribe how to get a cert via LiveConfig. Yet another site I’m not familiar with.
I thougt I could get a cert on an easy way. The reason for changing was, that I am up to my neck with dates in my calendar and wanted to let someanoe else take over. I got 72 last month.
So there is still some hope on my side. :wink:
