Wrong redirection
:wave: Hi there,
I created a Wordpress instance in DigitalOcean, and in the installation process I set a domain (activefacil.com) with Certbot. After this was set, I decided to use a different domain (eldiccionariocallejero.com) so I wanted to get rid of the initial domain.
I followed some instructions I found in this forum, but I'm still been redirected to activefacil.com instead of the good domain eldiccionariocallejero.com
If I run certbot certificates through the terminal, there is no evidence of the wrong domain (see below) but if I check it via https://check-your-website.server-daten.de/?q=eldiccionariocallejero.com I can still see a redirection to the wrong domain.
In Wordpress I have correctly set it with the new domain.
Any idea what else could I try?
Thank you
My domain is: eldiccionariocallejero.com
I ran this command: certbot certificates
root@ud3 : /etc # certbot certificates
Found the following certs:
Certificate Name: eldiccionariocallejero.com
Domains: eldiccionariocallejero.com www.eldiccionariocallejero.com
Expiry Date: 2020-12-08 13:32:32+00:00 (VALID: 76 days)
Certificate Path: /etc/letsencrypt/live/eldiccionariocallejero.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/eldiccionariocallejero.com/privkey.pem
root@ud3 : /etc #
My web server is (include version): Ubuntu WordPress on 18.04
The operating system my web server runs on is (include version): Ubuntu WordPress on 18.04
My hosting provider, if applicable, is: DigitalOcean
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no, only via ssh
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Welcome to the Let's Encrypt Community, Javier :slightly_smiling_face:
I did some checking and it looks like there is an unending redirect to activefacil.com that is only happening from http://www.eldiccionariocallejero.com and http://eldiccionariocallejero.com. It looks like https://www.eldiccionariocallejero.com and https://eldiccionariocallejero.com work fine.
