Newbie needs help getting Filecloud with SSL running
What happens after clicking "Install SSL Cert"?
I understand the newly acquired cert path is in Cerbot Live for ellisaircraft.com
I am confused where a private key and intermediate key is located.
Sorry to be such a PITA.
This is what I see after clicking on install SSL Cert.
Both of those entries are incorrect.
Please show the output of:
certbot certificates
How do I show the output?
These are in the certbot live folder for my domain
Filecloud community forum is poorly supported. Sometimes takes two weeks for someone to respond.
Use the fullchain and the privkey links to the most recent files.
[use the link paths (not the files they find) in the "Install SSL Cert"]
Do these paths look correct?
The last should be "chain.pem".
Actually all three have a TYPO:
elliscraft should be ellisAIRcraft
an SSL path error is returning
Looks like there is a space on the bottom one between the backslash \ and chain.pem
There was in fact a space. Stupid me.
but same error
should i try all three without the .pem?
I did notice some permission issues with the ellisaircraft.com folder
you have cerbot but I believe you need Certbot
Holy geese I'm spastic and blind.... Apache is running now.
I can't thank all enough!!!!!!
Thank you so much
It is working is thanks enough.
The "select" button might have been useful.
The select button was changing the path every time
Looking for advice now on shutting down filecloud in port 80
You do not have Port 443 open, the only open Port is 80.
$ nmap -Pn www.ellisaircraft.com
Starting Nmap 7.80 ( https://nmap.org ) at 2023-03-17 18:35 UTC
Nmap scan report for www.ellisaircraft.com (68.42.15.212)
Host is up (0.085s latency).
rDNS record for 68.42.15.212: c-68-42-15-212.hsd1.tn.comcast.net
Not shown: 999 filtered ports
PORT   STATE SERVICE
80/tcp open  http
Nmap done: 1 IP address (1 host up) scanned in 9.70 seconds
Also Best Practice - Keep Port 80 Open
