Newbie needs help getting Filecloud with SSL running
I'm using google domain and trying to get filecloud up and running on SSL
My web server is (include version):apache
The operating system my web server runs on is (include version): Windows 2016 server
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes. filecloud
Here is the error I'm receiving on the command prompt after using
C:\WINDOWS\system32> certbot certonly --standalone
www.ellisaircraft.com
Error
Any help is appreciated.
You'll want to go to your Google Cloud Domains and update your DNS records so that your domain points to your server.
You'll first need to remove the redirection to your IP address.
Then you'll need two "A" records:
  • ellisaircraft.com pointing to IP address 68.42.15.212 (assuming that's where certbot is running)
  • www.ellisaircraft.com pointing to IP address 68.42.15.212
Without doing these things first, you won't be able to get a certificate or get your website working.
Here is what I see for the domain name with nslookup.
$ nslookup -q=a ellisaircraft.com ns-cloud-a1.googledomains.com.
Server:         ns-cloud-a1.googledomains.com.
Address:        216.239.32.106#53
Address: 216.239.38.21
Address: 216.239.32.21
Address: 216.239.36.21
Address: 216.239.34.21
$ nslookup -q=aaaa ellisaircraft.com ns-cloud-a1.googledomains.com.
ellisaircraft.com       has AAAA address 2001:4860:4802:34::15
ellisaircraft.com       has AAAA address 2001:4860:4802:38::15
ellisaircraft.com       has AAAA address 2001:4860:4802:32::15
ellisaircraft.com       has AAAA address 2001:4860:4802:36::15
$ nslookup -q=cname www.ellisaircraft.com ns-cloud-a1.googledomains.com.
www.ellisaircraft.com   canonical name = ghs.googlehosted.com.
You are using the HTTP-01 challenge of the Challenge Types - Let's Encrypt
The HTTP-01 challenge can only be done on port 80 for each of the domain names in the SANs;
all IP Addresses (both IPv4 & IPv6) for each domain name needs to support this.
Thanks for helping
I removed the forwarding and added the two A entries.
At cmd prompt I seem to be having the same error. Thanks so much
NS lookup?
That's a different IP than what's my ip indicates.
Check using
curl -4 ifconfig.co
curl -6 ifconfig.co
or / and
curl -4 ifconfig.io
curl -6 ifconfig.io
Ok; presently I see. Which is agreeing with your screen shot above.
Address: 68.42.15.212
*** Can't find ellisaircraft.com: No answer
*** Can't find www.ellisaircraft.com: No answer
$ nslookup -q=a www.ellisaircraft.com ns-cloud-a1.googledomains.com.
I am aware you are
so likely nothing is presently on Port 80.
Using Let's Debug shows "www.ellisaircraft.com has an A (IPv4) record (68.42.15.212) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address." https://letsdebug.net/www.ellisaircraft.com/1379287
Best Practice - Keep Port 80 Open
Using nmap -Pn shows not accessible ports
$ nmap -Pn www.ellisaircraft.com
Host discovery disabled (-Pn). All addresses will be marked 'up' and scan times will be slower.
Starting Nmap 7.91 ( https://nmap.org ) at 2023-02-18 15:45 PST
Nmap scan report for www.ellisaircraft.com (68.42.15.212)
Host is up.
rDNS record for 68.42.15.212: c-68-42-15-212.hsd1.tn.comcast.net
All 1000 scanned ports on www.ellisaircraft.com (68.42.15.212) are filtered
Nmap done: 1 IP address (1 host up) scanned in 203.54 seconds
Thanks. Please recognize my gratitude.
Looking into ways of opening port 80 safely for authentication
I assume Web Server (IIS)
I'll let the Windows Server IIS knowledgeable Let's Encrypt community volunteers to assist.
I haven't used IIS. Yes to Win 2016 server.
The new "timeout during connect" error is progress :slight_smile: .
What you are missing now is that you will need to forward port 80 on your router/modem towards your Windows server, and permit port 80 traffic in your Windows Firewall.
You need to do this because Let's Encrypt needs to be able to connect to your website. At the moment it can't.
Sorry, my bad! :frowning:
Please look to Apache forums
Seem to be understanding thanks to all on how Lets Encrypt authenticates. So Many thanks!!!
There seems to still be some sort of firewall blocking the HTTP challenge requests.
I've rebooted the server, router. Trying certbot now
