Hello everyone, I have a problem.
I want to install an SSL certificate with Certbot on my Nextcloud. But every time I try this, I get the message "Some challenges have failed."**
Can someone please help me?
Thanks a lot!
Thanks a lot!
your nextcloud is running on openresty server: looks you selected wrong authenticator
Oh, how do I change that, and what do I need to change it to?
not much can say about without knowing how you set the server;
or certbot-auto --version
if you're using Certbot):
My domain is: nloi-nextcloud.de
I ran this command: as root: certbot —apache -m (my mail) -d nloi-Nextcloud.de
It produced this output: shown in the picture above
My web server is (include version): apache2.4.58
The operating system my web server runs on is (include version): Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: for the Domain and the VPN-Server -> because i have a DS-Lite connection is IONOS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): ?
if you're using Certbot): certbot 2.9.0
but you aren't running apache: it's openresty: where is it?
Where can I check that?
Sorry this is my first Owncloud
I can reach the Nextcloud over my Domain but the warning is already there. I think this is because i have no SSL certificate
form my viewpoint i seeing a nextcloud in openresty, and it do have valid certificate signed yesterday
does nginx proxy manger ring a bell to you?
That sounds good, but why is the message still there? Can I prevent access via HTTP in another way so that only HTTPS works?
Yes this is my reversed proxy manager
just specify https:// in client's url link: npm is painful to debug
You should modify your server so it redirects HTTP requests to HTTP. You should review the nextcloud docs or support forum if you need help configuring it. Or NPM if you have that too.
Or, as orangepizza said just be sure to use HTTPS:// in the browser address box
I can access Nextcloud via HTTPS, and it works. However, the message remains and significantly limits the functionality of my Nextcloud.
Can you tell me how to configure it so that HTTP requests are redirected to HTTPS?
I am not expert with NextCloud. Maybe some other volunteer here will know but you are better asking at a NextCloud forum or their support.
Probably related to it doing this (note from https it is redirect to http://)
curl -i https://nloi-nextcloud.de/index.php
HTTP/1.1 302 Found
Server: openresty
X-Served-By: nloi-nextcloud.de
Okay thank you guys. Have a nice day
