Hello
Please help, what could it be?
It work on January but now not. I have update cerbot due to TLS-SNI. I tried to stop nginx and run renewal it does not helped.
If the port for renewal has been changed from 443 to 80, maybe my nginx way to redirect all 80 request to 443 broke the renewal?
listen 79.174.65.34:80;
server_name itcooky.com www.itcooky.com ;
return 301 https://itcooky.com$request_uri;
My domain is: itcooky.com and some more
I ran this command: certbot-auto renew
Processing /etc/letsencrypt/renewal/itcooky.com.conf
http-01 challenge for itcooky.com
http-01 challenge for www.itcooky.com
Waiting for verification…
Challenge failed for domain www.itcooky.com
Challenge failed for domain itcooky.com
Attempting to renew cert (itcooky.com) from /etc/letsencrypt/renewal/itcooky.com.conf produced an unexpected error: Some challenges have failed… Skipping.
Domain: www.itcooky.com
Type: connection
Detail: Fetching
https://itcooky.com/.well-known/acme-challenge/tD_ToCHIXBNxO5t6KDmRJxZ3U35eP-KGrxZVFZ1HIs4:
Connection refused
Domain: itcooky.com
Type: connection
Detail: Fetching
https://itcooky.com/.well-known/acme-challenge/U7_u9soG8GVd3DFvCG-EFXLnS4ReEKADV18N7pj-i5o:
Connection refused
The operating system my web server runs on is (include version): centos 6
My hosting provider, if applicable, is: vps
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.33.1
