My domain is: mt.r8z.us
Installed cert-manager via microk8s configured dual stack, using traefik ingress. Service has publicly accessible IPV6 LB IP.
cert manager pod in namespace default (testing with simple web reflector pod) logs:
I1130 16:00:31.034534 1 solver.go:87] cert-manager/acmesolver "msg"="got successful challenge request, writing key" "base_path"="/.well-known/acme-challenge" "host"="mt.r8z.us" "path"="/.well-known/acme-challenge/(token removed)" "token"="(token removed)”
cert-manager pod in cert-manager namespace logs:
E1130 16:14:42.763988 1 sync.go:186] cert-manager/challenges "msg"="propagation check failed" "error"="failed to perfor
m self check GET request 'http://mt.r8z.us/.well-known/acme-challenge/(token removed)': Get "htt
p://mt.r8z.us/.well-known/acme-challenge/(token removed)": dial tcp [2601:300:4500:202::5:201]:80: connect: network is unreachable" "dnsName"="mt.r8z.us" "resource_kind"="Challenge" "resource_name"="mt.r8z.us-t9gll-598920
55-257349850" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
NOTE: I can go to that url from outside my network and resolve the challenge token, no problem. There’s no v4 address but the log says it can reach the IPv6 space for some reason, which path I know is good.
Traefik ingress
microk8s v1.25
I can login to a root shell on my machine (yes)
I'm using a control panel to manage my site (no)
or certbot-auto --version
if you're using Certbot): (“latest” image)
