Need to renew my ssl certificate
i had a free ssl certificate installed on my godaddy server 90 days ago but it just expired today, if someone can renew it i would really appreciate it, we can communicate outsite here and ill give you the login info so you can fix the problem\
My domain is: bangerperminute.com
My hosting provider, if applicable, is: godaddy
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel on godaddy
How did you create the current cert? You’ll need to go through the same process again, every 90 days. Or use a better web host.
i got it installed from sslforfree.com
would you be able to do it for me?
No, I’m not going to reconfigure your system. You installed it before; you’ll need to do it again.
so it cant be renewed?
it says contact lets encrypt to request a certificate renewal
There’s no such thing as “renewal”, really. There’s “issue a new cert that’s just like the last cert, but with different dates”. You get a new cert. You install it. You repeat every 80 days or so. Or you use a web host that doesn’t suck, and automates this for you.
Hi @mokorak
please read the basics.
There is your answer.
Do that again. Or switch to a provider with a better Letsencrypt support. It's your decision.
would you be able to fix it for me, im just dont know how to get the certificate renewal done
i just might have to remove it and install it again, thats the only way i know
