Do not know how to obtain a cert for this and then convert to PFX
Thanks
Thanks
Hi @nelmzee, and welcome to the LE community forum ![]()
This is not a VEEAM forum.
So, you may not get the most accurate / most specific help for that product here.
That said, there are ACME clients for most operating systems and we can help you with that part of the puzzle.
[as for converting a certificate into a .pfx file, there are many ways to do that - some are also "built into" the ACME clients themselves]
So, let us help you better by answering these basic questions:
Which platform does VEEAM run on? Is the server it's running on visible on the public internet?
Getting a cert starts with proving you control the domain using either an http challenge or dns challenge. These are handled by your ACME client software (of which there are many available but the most suitable will vary depending on your choice of OS, some natively produce PFX, some don't). Once you prove you control the domain you can get a cert issued, you then deploy that to whatever service as per that services own instructions. With short lived certificate you generally want to automate all this, which is what ACME clients are usually designed to do/help with.
