ACMEv1 update to ACMEv2
My domain is:web.kikoho.com
I ran this command: letsencrypt.exe from C:\letsencrypt
It produced this output:A Simple ACME Client for Windows (WACS)
My web server is (include version): IIS version 10
The operating system my web server runs on is (include version): Windows Server 2016 DC
My hosting provider, if applicable, is: Amazon
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 1912.2.6907.35819 (RELEASE)
I have not found an ACMEv2 version. Can I just change the client? I have not installed this and it was done by the previous admin. I have a folder in it with 4 scripts (ImportExchange, ImportRDGateway, ImportRDListener and ImportSSTP).
Sam.
Sounds like you are using win-acme 1.9.x: GitHub - win-acme/win-acme: A simple ACME client for Windows (for use with Let's Encrypt et al.)
If you upgrade to a newer release, it supports ACME v2.
It is probably worth reading through the migration notes at win-acme , as there appear to be some breaking changes.
