Need help renewal no longer possible
root@vorman:~/lets# ./certbot-auto renewal
Your system is not supported by certbot-auto anymore.
certbot-auto and its Certbot installation will no longer receive updates.
You will not receive any bug fixes including those fixing server compatibility
or security problems.
Please visit https://certbot.eff.org/ to check for other alternatives.
usage:
certbot-auto [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] ...
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: renewal
You should still be able to renew. The command is:
certbot-auto renew
ooops, thanks i was able with correct command but still showing due in 8 days i find that strange
Reload your webserver:
sudo apachectl -k graceful
or
sudo nginx -s reload
i did /etc/init.d/lighttpd reload
on my side shows expiration in ma7 but here when i check shows 7 days
https://www.sslshopper.com/ssl-checker.html#hostname=vorman.mooo.com
I think you're doing pretty good, my friend. :slightly_smiling_face:
https://www.ssllabs.com/ssltest/analyze.html?d=vorman.mooo.com&hideResults=on
Best check again... :wink:
You were probably looking at the cached results from sslshopper from before you reloaded your webserver. They cache them on the server. I updated the cache for you.
If this command doesn't work for you then stop the apache server and then retry the command again , it'll work.
