I am not creating but renewing’’
In rewind you have to answer all same questions when u created ?
GNU nano 2.7.4 File: letsencrypt.log
2018-12-06 17:08:47,354:DEBUG:certbot.main:certbot version: 0.29.1
2018-12-06 17:08:47,357:DEBUG:certbot.main:Arguments:
2018-12-06 17:08:47,357:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,Plu$2018-12-06 17:08:47,444:DEBUG:certbot.log:Root logging level set at 20
2018-12-06 17:08:47,447:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2018-12-06 17:08:47,665:DEBUG:certbot.plugins.selection:Requested authenticator <certbot.cli.Default obje$2018-12-06 17:08:47,864:DEBUG:certbot.storage:Should renew, less than 30 days before certificate expiry 20$2018-12-06 17:08:47,865:INFO:certbot.renewal:Cert is due for renewal, auto-renewing…
2018-12-06 17:08:47,866:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2018-12-06 17:08:47,893:DEBUG:certbot.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0x75b131f0>
Prep: True
2018-12-06 17:08:47,897:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Au$2018-12-06 17:08:47,898:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Installer $[ Read 349 lines ]
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos ^Y Prev Page
^X Exit^R Read File ^\ Replace ^U Uncut Text ^T To Spell ^ Go To Line ^V Next Page
2018-12-06 17:08:47,665:DEBUG:certbot.plugins.selection:Requested authenticator <certbot.cli._Default obje$2018-12-06 17:08:47,864:DEBUG:certbot.storage:Should renew, less than 30 days before certificate expiry 20$2018-12-06 17:08:47,865:INFO:certbot.renewal:Cert is due for renewal, auto-renewing…
Prep: True
2018-12-06 17:08:47,897:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Au$2018-12-06 17:08:47,898:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Installer $2018-12-06 17:08:47,910:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration$2018-12-06 17:08:47,915:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/dire$ GNU nano 2.7.4 File: letsencrypt.log
Prep: True
