Certificate expiration Please for help
My domain is: doumer.me
I received this message;
Your certificate (or certificates) for the names listed below will expire in
10 days (on 15 May 18 18:47 +0000). Please make sure to renew
your certificate before then, or visitors to your website will encounter errors.
Please what should I do in other to avoid that my certifcate expires
Depends on how you installed the certificates in the first place.
I installed it on google cloud on an apache server for wordpress
HOW*?
What commands did you run? Or did you use a control panel? If so, which one and how did you do it? Et cetera.
We are agreed, you setup the cert but haven’t setup automatic renewals.
https://crt.sh/?q=%doumer.me
My domain is : doumer.me
I used certbot to set my SSL,
Here are the commands :
wget https://dl.eff.org/certbot-auto && chmod a+x certbot-auto
./certbot-auto certonly --webroot -w /opt/bitnami/apps/wordpress/htdocs/ -d 1pagezen.com -d www.1pagezen.com
./certbot-auto renew --dry-run
Then I set this in my server in other to ensure auto renewal of my certificates :slight_smile: 0 0 * * * ./certbot-auto renew --quiet --no-self-upgrade
0 12 * * * ./certbot-auto renew --quiet --no-self-upgrade
Note I am using Apache and Bitnami
My apache version is Apache/2.4.29 (Unix)
The operasting system is linux : Debian 4.9.65-3+deb9u2
My hosting provider is Google Cloud
I dont know if I can login to a rootshell on my machine
No I’m not using a control panel to manage my site
You initially setup the cert via "certonly"
That does not set things up for future renewals.
Please place a test.txt file in the challenge folder:
http://doumer.me/.well-known/acme-challenge/text.txt
Also...
You have two redirects:
http://doumer.me/.well-known/acme-challenge/text.txt 302 Found
https://www.doumer.me/.well-known/acme-challenge/text.txt 301 Moved Permanently
https://doumer.me/.well-known/acme-challenge/text.txt
What do you mean by that, @rg305? certbot-auto renew would attempt to renew certificates that were obtained by certbot-auto certonly.
@schoen maybe it’s just lack of sleep…
I would need to see the renewal/<domain>.conf file to be sure.
But I’m thinking it wouldn’t know about webroot or Apache and would be like running:
certbot-auto renew --manual -d domain --quiet
unattended in a script.
[EDIT]
Should maybe read more clearly as:
That does not guarantee that things are setup properly for future renewals.
When you get a certificate via certonly, it creates a renewal configuration file in /etc/letsencrypt/renewal and the settings in that file will be used by renew. If the authenticator is manual, then the renewal can’t work unless you also provided an auth-hook. Otherwise, the renewal will use the same settings that were first used with certonly, and should work properly.
Ok, so we need to see what is in:
/etc/letsencrypt/renewal/<domain>.conf
to be 100% certain.
At this point we don’t even know what version of certbot/certbot-auto is being used.
Given: Whenever a cert is received, the renewal/.conf file is created/updated.
But that doesn’t ensure that exact setting can be used for renewals (not 100%).
Having a look at the /var/log/letsencrypt/letsencrypt.log may also prove helpful.
This may also be providing unexpected results; as the start location may not align with where certbot-auto can be found. Where was he "standing" when he downloaded it to his location?
Calling it explicitly would ensure that it was run. Like:
0 0 * * * /complete/path/to/certbot-auto renew --quiet --no-self-upgrade
0 12 * * * /complete/path/to/certbot-auto renew --quiet --no-self-upgrade
To that end, I suggest finding it and updating the cronjob with the complete file path.
which certbot-auto
cd / && find / -name certbot-auto
one, or both, should provide the location.
certbot-auto from a distinct directory and cron could be a pickle indeed.
I would recommend building a cronjob with two commands combined with &&:
  1. cd /directory/where/certbot-auto/is/located/
  2. and ./certbot-auto renew
So you would get: cd /directory/where/certbot-auto/is/located/ && ./certbot-auto renew
Do note: with certonly your webserver won’t recognise the new certificate: it needs to be reloaded after the certificate was renewed.
To mitigate that shortcoming, you can add the Apache reload command from your OS to the --deploy-hook option of certbot.
That move should be the first lines of code in certbot-auto
Find yourself, cd to that directory, then begin...
The problem with ./certbot-auto in a cronjob isn't really that certbot-auto will try to refer to the current working directory for any of the tasks that it performs, but that the operating system won't be able to find the certbot-auto program so it won't be able to start at all.
ah yes, chicken and egg problem…
So then his cronjob may have never been running at all.
And calling it explicitly may not produce the desired results either.
Then @Osiris method would have to be used to ensure desired results.
cd <to location> && ./certbot-auto ...
I’m really Sorry, I wasnt online.
Please I’ve gone through all the messages and replies made for my issue. But I don’t really the best one to pick in other to solve my problem.
what I did is I first renewed it manually while waiting for a solution.
Here is the command I used for this renewal : ./certbot-auto renew --dry-run
Please show:
Ok, let me access it and I’ll send it here
Here is the content of var/log/letsencrypt/
renew_before_expiry = 30 days
version = 0.21.1
archive_dir = /etc/letsencrypt/archive/doumer.me
cert = /etc/letsencrypt/live/doumer.me/cert.pem
privkey = /etc/letsencrypt/live/doumer.me/privkey.pem
chain = /etc/letsencrypt/live/doumer.me/chain.pem
fullchain = /etc/letsencrypt/live/doumer.me/fullchain.pem
[renewalparams]
authenticator = webroot
installer = None
account = 1235b294af025ea9a043f4d05a789184
webroot_path = /opt/bitnami/apps/wordpress/htdocs,
[[webroot_map]]
doumer.me = /opt/bitnami/apps/wordpress/htdocs
www.doumer.me = /opt/bitnami/apps/wordpress/htdocs
