so how to solve it ?
From here SSL Server Test: recruitopen.com (Powered by Qualys SSL Labs)
I highly suggest stop offering this EXPIRED Certificate #2 as None SNI will possible us it.
Actually I disagree; I believe the certificate was updated to this crt.sh | 11852165767 one
Valid from Wed, 24 Jan 2024 09:41:45 UTC
crt.sh | recruitopen.com
actually i had the certificate that was valid till march 2024 which i renewed on december 2023. Since it showed the "not secured" issue i renewed it again today afternoon
Did you just make a change? Because I was getting a failure using HTTPS with curl to your site but now the connection works.
But, your server redirects the HTTPS request to HTTP which is poor practice and browsers may warn about.
And, the HTTPS connection is using a cert from apnigiftshop.com
. Do you know what that is?
I think you should start be rebooting your server. And, please let us know what operating system and version and openssl version you have. I don't see any problems with your certs but likely problems with ciphers or other server config.
Your nginx says it is 1.4.6 which is like 10 years old.
curl -i https://recruitopen.com
curl: (56) OpenSSL SSL_read: error:0A000126:SSL routines::unexpected eof while reading, errno 0
# and just 1 minute later connection works but wrong cert
curl: (60) SSL: no alternative certificate subject name matches target host name 'recruitopen.com'
More details here: https://curl.se/docs/sslcerts.html
# Is this cert
subject=CN = apnigiftshop.com
issuer=C = US, O = Let's Encrypt, CN = R3
notBefore=Dec 19 09:05:48 2023 GMT
notAfter=Mar 18 09:05:47 2024 GMT
Well to start with, to help other more knowledgeable Let's Encrypt community volunteers to assist,
My domain is: recruitopen.com
My web server is (include version): nginx/1.4.6 (Ubuntu)
The operating system my web server runs on is (include version): ? Ubuntu
My hosting provider, if applicable, is: ? DIGITALOCEAN
or certbot-auto --version
if you're using Certbot):
Thank you for assisting us in helping YOU!
Your system is very unstable. I suggested restart and still do.
Here's one response I saw. Note a connect to recruitopen on HTTPS but it redirected to ww12 subdomain as HTTP
And, nginx version for ww12 is 1.10.3 but your other nginx is 1.4
curl -Ik https://recruitopen.com
HTTP/1.1 302 Found
content-length: 0
cache-control: no-cache
That is the issue ,I havent made any changes. i dont no why its using the certificate from apnigiftshop.com
. It keep on changing . sometimes the site opens smoothly but then sometimes its shows as not secured
Who hosts your server? Something has obviously changed.
I get a valid TLS connect (using cert) from openssl on my own system but yet curl fails. Makes me think of something like a changed openssl version on your system. Or some other operating system component.
echo | openssl s_client -connect recruitopen.com:443 | (head -20)
Certificate chain
0 s:CN = recruitopen.com
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
v:NotBefore: Jan 24 09:41:45 2024 GMT; NotAfter: Apr 23 09:41:44 2024 GMT
# yet curl right after that fails
This https://check-your-website.server-daten.de/?q=recruitopen.com shows "old / weak connection"
How to rectify it?
I don't know. Your problems don't look related to Let's Encrypt certs
Sounds like your problems started before you got your fresh certs today. Look at all the recent changes to your system. Consult with your hosting company. Or, consult a server or networking specialist.
I am guessing DIGITALOCEAN-143-110-128-0 ARIN Whois/RDAP - American Registry for Internet Numbers
Yes , i got the fresh certificate assuming that its the issue to ssl certificate as the brower showed insecure connection
Thank you , I will contact digital ocean
Found this topic just now myself looking for apnigiftshop.com
when I got cert errors on some of my stuff. I self-host everything with a certbot docker image to renew my certs. I got several cert error popups about mismatching hostnames on some of my stuff. I'm also getting the same issue for all my domains under the cert, also issued in December. I forced it to do a renew on the certs and it seems fine, but it's still weird. I wonder if certbot had an issue and gave everybody certs for that domain? Googling on it I see a bunch of SSL reports of random domains with that as the cert name.
Alternatively I guess it could be a DNS issue, I wonder if some root server somewhere started resolving hostnames to the wrong place. Sadly I didn't keep any of the error popup contents that had cert details, I'll see if I can dig them up.
Actually, I just figured out the issue I'm pretty sure. Both my domain and recruitopen.com
are registered with Namecheap. My autorenew failed and my domain was close to expiration (today, actually), and it looks like Namecheap helpfully starts randomly redirecting nearly-expired domains to various sponsors and parking websites informing about the impending expiration. Once I renewed my domain all the weirdness went away and it's back to normal. I'd guess my manual renewing of my certs didn't actually do anything and was coincidental with the random redirection Namecheap does.
Of course, with any sort of sensible certificate validation turned on, things get very cranky when an https URL redirects to an unexpected location, and I'd guess apnigiftshop[.]com
is one of the sponsors it redirected to. Not sure how I feel about that, I wonder if I can disable that redirection with Namecheap.
I think this should be the issue, my domain is about to expire or probably has expired and it's from namecheap too. Got that apnigiftshop message and certbot notification.
