My site is hitting error 500 i couldnt proceed when the first two lines of code on how to secure apache
My domain is:jobsdojo.com
sudo apache2ctl configtest
AH00526: Syntax error on line 1 of /etc/letsencrypt/options-ssl-apache.conf:
Invalid command '404:', perhaps misspelled or defined by a module not included in the server configuration
Action 'configtest' failed.
ubuntu 20
no
Hello @, welcome to the Let's Encrypt community. :slightly_smiling_face:
What version of Certbot?
What version of Apache?
Please post the logs and the file /etc/letsencrypt/options-ssl-apache.conf
To upload a file use this
options-ssl-apache.conf 404: Not Found... file conttains that
Kindly wait for more knowledgeable Let's Encrypt community volunteers to assist.
i managed to install it now. yet my site is still not secure
i used snapd. site is working now but still http
How?
The file options-ssl-apache.conf should NOT contain the text "404: Not Found...". It seems something has overwritten the original contents.
this time it doesnt contain 404
Using this online tool SSL Server Test (Powered by Qualys SSL Labs) gets a B here SSL Server Test: jobsdojo.com (Powered by Qualys SSL Labs)
With curl -Ii
HTTPS connects but is returning "HTTP/1.1 500 Internal Server Error"
$ curl -Ii https://jobsdojo.com
Date: Tue, 21 Mar 2023 20:03:40 GMT
Server: Apache/2.4.29 (Ubuntu)
Connection: close
HTTP looks ok
$ curl -Ii http://jobsdojo.com/
HTTP/1.1 200 OK
Date: Tue, 21 Mar 2023 20:03:10 GMT
Content-Length: 89567
X-Frame-Options: DENY
Vary: Cookie,Accept-Encoding
X-Content-Type-Options: nosniff
Referrer-Policy: same-origin
Set-Cookie: csrftoken=JD4Lyni2nF6Lh62JzHJP0OJWQIxWtSBre7TEDpvXsj43JNyGtG9xeq8VFHN6IvRG; expires=Tue, 19 Mar 2024 20:03:10 GMT; Max-Age=31449600; Path=/; SameSite=Lax
Content-Type: text/html; charset=utf-8
And the Certificate via openssl
$ openssl s_client -showcerts -servername jobsdojo.com -connect jobsdojo.com:443 < /dev/null
CONNECTED(00000003)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = jobsdojo.com
verify return:1
Certificate chain
 0 s:CN = jobsdojo.com
   a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
   v:NotBefore: Mar 21 18:42:42 2023 GMT; NotAfter: Jun 19 18:42:41 2023 GMT
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
   v:NotBefore: Sep  4 00:00:00 2020 GMT; NotAfter: Sep 15 16:00:00 2025 GMT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 2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
   i:O = Digital Signature Trust Co., CN = DST Root CA X3
   a:PKEY: rsaEncryption, 4096 (bit); sigalg: RSA-SHA256
   v:NotBefore: Jan 20 19:14:03 2021 GMT; NotAfter: Sep 30 18:14:03 2024 GMT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Server certificate
subject=CN = jobsdojo.com
issuer=C = US, O = Let's Encrypt, CN = R3
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 4571 bytes and written 394 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 2048 bit
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
DONE
yes. http works fine
Your are serving a Let's Encrypt Certificate properly; the main goal to the forum to my knowledge.
Here details on Apache can be found in documentation and forums:
Kindly wait to see if there are more knowledgeable Let's Encrypt community volunteers willing to assist.
okay. thanks
We have no clue what has happened, as we're lacking information, even when asked about it.
Certbot usually can add the HTTP to HTTPS redirect, but that will only happen when the apache authenticator is used. As options-ssl-apache.conf was in use, this suggests some use of the apache authenticator. Maybe Certbot had some issues with the Apache configuration or something else has happend. Which wouldn't surprise me, as the contents of options-ssl-apache.conf were modified also.
Please post the output of:
sudo apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 jobsdojo.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 jobsdojovm.europe-west2-c.c.jobsdojo-378008.internal (/etc/apache2/sites-enabled/000-default.conf:1)
# this file.
SSLEngine on
# Intermediate configuration, tweak to your needs
SSLProtocol             all -SSLv2 -SSLv3
SSLCipherSuite          ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder     on
SSLCompression          off
SSLOptions +StrictRequire
# Add vhost name to log entries:
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\"" vhost_combined
LogFormat "%v %h %l %u %t \"%r\" %>s %b" vhost_common
#CustomLog /var/log/apache2/access.log vhost_combined
#LogLevel warn
#ErrorLog /var/log/apache2/error.log
# Always ensure Cookies have "Secure" set (JAH 2012/1)
#Header edit Set-Cookie (?i)^(.*)(;\s*secure)??((\s*;)?(.*)) "$1; Secure$3$4"
That's weird: where is the HTTP (port 80) virtualhost for jobsdojo.com gone to? Could you post the contents of /etc/apache2/sites-enabled/000-default.conf?
<VirtualHost *:80>
	# specifies what hostname must appear in the request's Host: header to
	#ServerName www.example.com
	#ServerName www.jobsdojo.com
	#ServerAlias jobsdojo.com
	DocumentRoot /var/www/blog
   	 Alias /static /var/www/blog/static
   	 <Directory /var/www/blog/static>
       		 Require all granted
   	 </Directory>
   	 <Directory /var/www/blog/blog>
       	 <Files wsgi.py>
            Require all granted
       	 </Files>
  	 </Directory>
   	 WSGIDaemonProcess blog python-path=/var/www/blog/:/usr/bin/python3/
   	 WSGIProcessGroup blog
   	 WSGIScriptAlias / /var/www/blog/blog/wsgi.py
	# error, crit, alert, emerg.
	# modules, e.g.
	#LogLevel info ssl:war
	#Include conf-available/serve-cgi-bin.con
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Hmkay, so no redirect added by Certbot.
Any reason why this is commented? When commented, Certbot probably can't find the vhost to add a redirect. However, as 000-default-le-ssl.conf is based on 000-default.conf it must have been uncommented before. So I don't understand. It looks like much was manually edited after Certbot was used?
so i should uncomment it?
it is actually uncommented in sites-available.
