Certifiactes come with a permission mask, connection to this is not secure
https://35.154.101.44/
Ubuntu: 16.04
AWS cloud computing
Yes
No
apachectl configtest
AH00526: Syntax error on line 34 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/welldoneindia.co.in/fullchain.pem' does not exist or is empty
Action 'configtest' failed.
Actually the file really exists and not empty
This above URL will ask you to confirm security exception , But the file is really working 000-default-le-ssl.conf
Probably you forgot to run it as root (or with sudo).
Indeed, because your certificate is not valid for an IP address. Let's Encrypt will only issue certificates for registered domain names. If you visit the website over one of the names that the certificate is valid for (e.g. https://welldoneindia.co.in), then you will see that there is no error.
Does this domain https://welldoneindia.co.in/ works for you ?
@_az
Yes it does, as well as https://www.welldoneindia.co.in/ and https://app.welldoneindia.co.in/
Unfortunately , this does not works for me in private as well @_az, Can you please send me the working screenshot for that
Maybe try re-opening your browser tab, and also checking that you don’t have your domains pointing somewhere else in /etc/hosts.
Yes, I already check the /etc/hosts., but it seems fine, But thanks for your help may be ISP blocked that IP for me
Do you any other option, So I can access the same @_az
Thanks
What’s the actual error message shown by your browser? Take a screenshot of the most detailed part of the error.
Please look for the following attachment
Your computer can’t resolve the domain in DNS.
Perhaps you have a cached NXDOMAIN on your local network’s resolver from before you had setup up the IP address in Route 53.
You’ll just need to wait for your local DNS resolver to update, or flush it, or change DNS resolver to something like 1.1.1.1 temporarily.
Thanks for the info , you are very helpful @_az
