My site has a B rating because of certificate "chain issues"
My domain is: mysoccerleague.com
I ran this command: SSL Server Test: mysoccerleague.com (Powered by Qualys SSL Labs)
It produced this output: This server's certificate chain is incomplete. Grade capped to B.
My web server is (include version): Tomcat 8.5.24.0
The operating system my web server runs on is (include version): AlmaLinux release 9.6
My hosting provider, if applicable, is: eApps
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): It doesn't appear to be installed.
your server doesn't send intermediate certificate.
Looks like you need to tweak your apache config.
check if "SSLCertificateFile" only contains the signed cert or signed cert and intermediate certs
    SSLCertificateFile      /path/to/signed_cert_and_intermediate_certs
    SSLCertificateKeyFile   /path/to/private_key
For certbot etc this generally means you want to point to the "fullchain" file, not the "cert" file.
