CertBot Certificate Chain Automation Grade Cap
My domain is: cloudyhost.net
My web server is (include version): Apache 2.4.29 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.2 LTS Server
My hosting provider, if applicable, is: Contabo
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot 0.39.0
Hi there,
I have generated certificates for my domain via certbot, and configured them in Apache as SSLCertificateFile, SSLCertificateKeyFile and SSLCertificateChainFile.
I am using the fullchain in the domain live folder for the chain file.
SSL is working as expected, however Qualys SSL Labs check is capping me to Grade B saying
This server's certificate chain is incomplete. Grade capped to B.
https://www.ssllabs.com/ssltest/analyze.html?d=cloudyhost.net
I have looked at the chain file myself and it is generated automatically as the cert.pem contents followed by the chain.pem contents.
I would like to achieve an A+ and this is the only thing preventing me. How can I fix this without manually modifying the chain file every single renewal?
Hi @alexhorner
looks like you have done something wrong. There is an incomplete chain - https://check-your-website.server-daten.de/?q=cloudyhost.net#connections
Chain - incomplete
1 CN=cloudyhost.net
No intermediate certificate is sent.
Share these three rows with the SSLCertificateFile ... parameters. A server restart is required.
Hi there,
Here are the directives
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/cloudyhost.net/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/cloudyhost.net/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/cloudyhost.net/privkey.pem
That's wrong:
SSLCertificateChainFile must have the fullchain.pem, not the privkey.pem a second time. Change it, restart the server, then recheck the domain.
Oh man, I didn’t even notice, how embarrasing.
Thats a pretty bad misconfig. I probably need to renew my certificates now for private key security right?
The SSLLabs test passed now, thank you for your help!
The current configuration is still incorrect. :sweat: It’s sending your certificate twice and the intermediate certificate once. Many clients will ignore the extra certificate, but some are stricter and will be unable to connect.
You need to use:
SSLCertificateChainFile /etc/letsencrypt/live/cloudyhost.net/chain.pem
Or, in Apache 2.4.8 or newer, the equivalent but more concise:
SSLCertificateFile /etc/letsencrypt/live/cloudyhost.net/fullchain.pem
