I run multiple WordPress sites under various subdomains. The last certificate renewal failed, but thanks to Google and this forum, this now sort of works. This is what happens now.
curl -i https://www.grendel.no
returns
curl: (51) SSL: certificate subject name (grendel.no) does not match target host name 'www.grendel.no
This runs with no errors:
certbot --apache certonly -w ~vds/www/blog.grendel.no -d grendel.no -d blog.grendel.no -d r.grendel.no -d www.grendel.no -d ptsd-boken.grendel.no
Please find log below.
Any and all hints and suggestions appreciated.
grendel.no
requested (ref: /etc/letsencrypt/renewal/grendel.no-0004.conf)
It contains these names: grendel.no, blog.grendel.no, r.grendel.no
You requested these names for the new certificate: grendel.no, blog.grendel.no,
r.grendel.no, www.grendel.no, ptsd-boken.grendel.no.
certificate?
(E)xpand/(C)ancel: E
http-01 challenge for grendel.no
http-01 challenge for blog.grendel.no
http-01 challenge for r.grendel.no
http-01 challenge for www.grendel.no
http-01 challenge for ptsd-boken.grendel.no
/etc/letsencrypt/live/grendel.no-0004/fullchain.pem
/etc/letsencrypt/live/grendel.no-0004/privkey.pem
Your cert will expire on 2018-06-12. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew *all* of your certificates, run
"certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Apache/2.4.18 (Ubuntu) mod_R/1.2.8 R/3.2.3 OpenSSL/1.0.2g mod_apreq2-20090110/2.8.0
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
www.webhuset.no
Yes
No
