Multi Domain encryption
I am wondering if Let’s Encrypt offers multi domain certificates. I own several websites and would like to encrypt all of them, or should I obtain a separate SSL for each domain?
My domain is: http://westgatedigital.com
The operating system my web server runs on is (include version): Apache
2.2.24 and 2.2.25
My hosting provider, if applicable, is: Hostgator
I can login to a root shell on my machine (yes or no, or I don’t know): no
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
This is completely your choice. However, my usual way is issuing one certificate for one domain including all subdomains (at least: www).
Depends on the following:
This would suggest you don't have any low-level control over your webserver. Everything depends on what Hostgater offers you.
You should look in your control panel for something like SSL or TLS and see what options Hostgater offers you.
