Hi all. I am fairly new to LE and still getting used to it.
Can one run the manual mode ./letsencrypt-auto certonly -a manual --rsa-key-size 4096 -d domain.com -d www.domain.com
with --test-cert
to do a test run?
Thanks.
with --test-cert
to do a test run?
Thanks.
Yep! manual
just means that the client won’t create the verification files for you; other than that there’s no difference. The process is the exact same with the production environment, you just get a untrusted certificate in the end.
No, certificates issued by the staging environment are not trusted, and are not submitted to the CT logs.
