Could not add certificate via manual mode
Hello,
I’m having problems when create a certificate for my test site.
Below here are all the steps and its output:
sudo ./certbot-auto certonly --manual --preferred-challenges=http
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): sldev10.com www.sldev10.com
http-01 challenge for sldev10.com
http-01 challenge for www.sldev10.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Create a file containing just this data:
rbRL1RrSPR5kNBYc5nRWiJPZRx-60MkpJYzy7V6Nxqg.7O9Gg7AAWp8yY2V4wJBwt8mJ6jH65RboTwyLcrxUFEw
http://sldev10.com/.well-known/acme-challenge/rbRL1RrSPR5kNBYc5nRWiJPZRx-60MkpJYzy7V6Nxqg
Press Enter to Continue
aiC_HlecOjT9ooc53MIUj-XoTUuED4AbYvYvp7WEwOg.7O9Gg7AAWp8yY2V4wJBwt8mJ6jH65RboTwyLcrxUFEw
http://www.sldev10.com/.well-known/acme-challenge/aiC_HlecOjT9ooc53MIUj-XoTUuED4AbYvYvp7WEwOg
Waiting for verification…
    /etc/letsencrypt/live/sldev10.com/fullchain.pem
    /etc/letsencrypt/live/sldev10.com/privkey.pem
    Your cert will expire on 2018-12-13. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again. To non-interactively renew all of your certificates, run
    “certbot-auto renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
However, when go to the site via https protocol, the browser couldn’t recognize the certificate. What did I miss?
The manual plugin only obtained a certificate, but never help you installed it…
You would need to install it manually…
However, if you are using Apache or Nginx on Linux system that directly running the commands, you could use certbot certonly
Thank you
It would probably be even better not to use certonly and to let Certbot install the certificate for you (just with certbot --apache or certbot --nginx)!
@thuynh, your server headers suggest that you're running Apache with cPanel. Is that true? Could you try to get the certificate inside of cPanel using its built-in Let's Encrypt integration instead of using Certbot at all?
@thuynh : for schoens point... It's better to request and install certificate directly in cPanel..
Follow this guide for cPanel autossl.
https://confluence1.cpanel.net/plugins/servlet/mobile?contentId=14001305#content/view/14001305
Thank you
