Not able to create certificate using certbot certonly manual
Hello everyone!
I want to request a certificate for a test subdomain, I don’t have access to the DNS of the subdomain neither the web server. So I want to create the cert remotely from my computer.
~/tmp/certbot 6s » ./poc.sh
Saving debug log to /home/n0kt/tmp/certbot/letsencrypt.log
http-01 challenge for nossl.nextbrave.com
Running manual-auth-hook command: authenticator.sh
Challenge failed for domain nossl.nextbrave.com
Running manual-cleanup-hook command: cleanup.sh
   Domain: nossl.nextbrave.com
   Type:   unauthorized
   Detail: Invalid response from
   http://nossl.nextbrave.com/.well-known/acme-challenge/egWv9oqQhipIZ5MepUmKKzmKXJgdf15p8NvN3hrI3zw
   [52.216.184.242]: "<html>\n<head><title>404 Not
   Found</title></head>\n<body>\n<h1>404 Not
   Found</h1>\n<ul>\n<li>Code: NoSuchBucket</li>\n<li>Message: The"
   configuration directory at /home/n0kt/tmp/certbot. You should make
   a secure backup of this folder now. This configuration directory
   will also contain certificates and private keys obtained by Certbot
   so making regular backups of this folder is ideal.
And the script I’m using this command:
AUTH_SRV_PORT=8000
certbot certonly --manual \
  -m myemail@gmail.com \
  --config-dir . \
  --work-dir . \
  --logs-dir . \
  --agree-tos \
  --no-eff-email \
  --preferred-challenges=http \
  --manual-auth-hook authenticator.sh \
  --manual-cleanup-hook cleanup.sh \
  --manual-public-ip-logging-ok \
  --http-01-port $AUTH_SRV_PORT \
  -d nossl.nextbrave.com \
  --dry-run
That command is supposed to create the cert manually without the need to have access to the target web server. am I right?
Thanks in advance.
The idea is that authenticator.sh would deploy the challenge response file to your webserver.
There's no way to bypass the challenge, you need to do it one way or another. Otherwise any person would be able to create a certificate for any domain.
