Malformed URL manual verification
Manually verifying never succeeds due a malformed URL, the / is missing; if I add the / the link is fine:
https://bernhard.hensler.net.well-known/acme-challenge/HGqB38utTQJ9bSBDT3VTDTtBjUROD5N6859GaCiJpjE
https://bernhard.hensler.net/.well-known/acme-challenge/HGqB38utTQJ9bSBDT3VTDTtBjUROD5N6859GaCiJpjE
Is that an Apache server problem? I use the latest Firefox, Safari fails as well … macos High Sierra, Server version: Apache/2.4.27 (Unix).
Thanks
bernhard
Which Client/Tool are you using?
going now for the certbot plugin and making progress, thanks!
Do you have an HTTP to HTTPS redirect in your Apache configuration? I'm guessing that the HTTP-01 validation request arrives well formed but loses a / when the configuration redirects it to HTTPS.
Can you share your Apache configuration?
