Local Computer Does not Recognise Lets Encrypt SSL Cert
Get this back:
C:\Users\User>ping WWW.theglowsonic.com
Pinging theglowsonic.com [92.204.68.16] with 32 bytes of data:
Reply from 92.204.68.16: bytes=32 time=31ms TTL=50
Reply from 92.204.68.16: bytes=32 time=27ms TTL=50
Ping statistics for 92.204.68.16:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 27ms, Maximum = 31ms, Average = 30ms
Copyright (c) 1993-2009 Microsoft Corp.
This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
This file contains the mappings of IP addresses to host names. Each
entry should be kept on an individual line. The IP address should
be placed in the first column followed by the corresponding host name.
The IP address and the host name should be separated by at least one
space.
Additionally, comments (such as these) may be inserted on individual
lines or following the machine name denoted by a '#' symbol.
For example:
102.54.94.97 rhino.acme.com # source server
38.25.63.10 x.acme.com # x client host
localhost name resolution is handled within DNS itself.
127.0.0.1 localhost
::1 localhost
92.204.68.16 theglowsonic.com www.theglowsonic.com
NEED I SAY MORE?
so, (bit dense here) - what is the problem, different IP?
Your system has been hardcoded to go to that IP (always and forever).
[until you remove that entry]
That is an old entry from a previous provider.
OK, so what do I do? Is there light at the end of the tunnel? (at last?)
Yes, the light says:
Remove that entry from that file.
OK, so I remove the entire line: 92.204.68.16 theglowsonic.com www.theglowsonic.com ?
D
After ~100 posts, light has been seen
Yes. That IP is from an old host
Yes, and save the file.
Then test it again WITH PING from the cmd prompt.
I know, but cloudways support it was days and days, days... and still no joy
Must be nice!
Charge more and do less!
OK, so once I remove the line, I ping with the url?
D
Once you can PING the names and they return the new IP (178.62.110.86), then we are in the clear.
OK, doing so now. Be a minute.
You can't PING a URL.
Use only the names.
[scroll up to see the way we did it before]
C:\Users\User>ping theglowsonic.com
Pinging theglowsonic.com [178.62.110.86] with 32 bytes of data:
Request timed out.
PERFECT!
Now update your site as you would from any Cafe.
