Griffin,
Not sure - I think I have signed out of the WP backend on my home computer. I always sign out on any external computer I use. I will check now.
D
Griffin,
D
From your PC, what IP do you show when you ping your domain name?
@griffin, me too!
Trying to figure out why outside-in works, while inside-in fails...
NAT to different port?
Using different names?
ping says IP 92.204.68.16:
Is that where you also are?
Is the server on the same LAN with your PC?
That's not the IP in the A record. Did you ping your website or yourself?
Seeing any content isn't being blocked.
Seeing wrong content means wrong "site".
That's probably a name change or accessing wrong port/name.
And the light starts to shine...
TSO found via dig
OK, that is interesting.
I was intially on another host and because the site uses Elemenator which I found slowed everything down, I migrated to cloudways but cloudways say that If I want to maintain my email I should still use my previous host which was TSO host. So on TSO host for email and Cloudways for hosting the actual site.
My IP is 80.7.139.193
D
Odd thought...
Is there a load balancer in play here? That would explain EVERYTHING.
DNS I think is via TSO host?
Really I thought that when I was using Cloudways that I would only need to use one host. Not the case. Have spent hours with Cloudways support and no joy so just accepted. However, I have not felt confident in launching the site.
D
(Global Load Balancer)
I get a completely different IP: 178.62.110.86
That's the correct IP, @rg305, via the A record.
@dnom, exactly what name did you ping?
Perhaps there is TYPO???
My thoughts exactly, @rg305.
I pinged the domain name theglowsonic.com
D
Actually, I forgot. Can't access WP backend on my local computer (I did update the password etc) Able to access on any external computer which is not my home computer.
I am also with Virgin Media, could that be a problem?
D
Non-authoritative NS? hosts file?
