Load Resource Directory 14090086
My domain is: workfolders.maraisviljoen.co.za
I ran this command: le64.exe -generate-missing -key account.key -csr domain.csr -csr-key domain.key -crt domain.crt -domains "workfolders.maraisviljoen.co.za" -path "C:\inetpub\wwwroot.well-known\acme-challenge" -unlink -renew 60 -live -handle-as http
2023/01/09 15:49:21 [ Crypt::LE client v0.38 started. ]
2023/01/09 15:49:21 Loading an account key from account.key
2023/01/09 15:49:21 Loading a CSR from domain.csr
2023/01/09 15:49:21 Checking certificate for expiration (local file).
2023/01/09 15:49:21 Expiration threshold set at 60 days, the certificate expires in 5 days - will be renewing.
2023/01/09 15:49:24 Could not load the resource directory: SSL connection failed for acme-v02.api.letsencrypt.org: SSL connect attempt failed error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
My web server is (include version): IIS 10
The operating system my web server runs on is (include version): Windows Server 2016
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): LE64 v0.38
Found the issue. The ISP was having a routing issue and it was stopping some requests getting through. Problem is now cleared up.
OK, glad to see it's sorted out - the verification of the server cert helps with the potential "man-in-the-middle" situations, so if the ISP for some reason lands you on their own page when you request a specific resource (due to filtering or some other issues), this would indeed trigger an error.
I have also replied on Github - if you feel that it's indeed resolved, please add a comment there, and I will close that issue.
Thanks.
