Hi there,
My domain is: xai.sh
acme-tiny --account-key account.key --csr xai.sh.csr --acme-dir /var/www/challenges
Parsing account key...
Parsing CSR...
Found domains: www.xai.sh, xai.sh
Getting directory...
Directory found!
Registering account...
Already registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/1117856
Creating new order...
Order created!
File "/usr/bin/acme-tiny", line 33, in
sys.exit(load_entry_point('acme-tiny==5.0.1', 'console_scripts', 'acme-tiny')())
File "/usr/lib/python3/dist-packages/acme_tiny.py", line 195, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact, check_port=args.check_port)
File "/usr/lib/python3/dist-packages/acme_tiny.py", line 125, in get_crt
authorization, _, _ = _send_signed_request(auth_url, None, "Error getting challenges")
File "/usr/lib/python3/dist-packages/acme_tiny.py", line 60, in _send_signed_request
return _do_request(url, data=data.encode('utf8'), err_msg=err_msg, depth=depth)
File "/usr/lib/python3/dist-packages/acme_tiny.py", line 46, in _do_request
raise ValueError("{0}:\nUrl: {1}\nData: {2}\nResponse Code: {3}\nResponse: {4}".format(err_msg, url, data, code, resp_data))
ValueError: Error getting challenges:
Url: https://acme-v02.api.letsencrypt.org/acme/authz-v3/374463490457
Data: b'{"protected": "[...]", "payload": "", "signature": "[...]"}'
Response Code: None
Response: <urlopen error TLS/SSL connection has been closed (EOF) (_ssl.c:992)>
My web server is (include version): nginx/1.22.
The operating system my web server runs on is (include version): Debian 12.6
My hosting provider, if applicable, is: hetzner.de
or certbot-auto --version
if you're using Certbot): ACME tiny 5.0.1 (from Debian package or upstream git repository, makes no difference)
The renewal has been working for years, but this time, acme tiny stops at some (random?) point, waits for some time and then quits with "urlopen error TLS/SSL connection has been closed (EOF)". This may happen at different points in the process, sometimes as in the output shown above, sometimes when doing the verification,...
It works with --directory-url https://acme-staging-v02.api.letsencrypt.org/directory.
Let's debug also reports that everything is ok: Let's Debug
We have the exact same issue also with other domains on this machine.
We have been debugging this for some hours now, but without success. Any help/hint would be highly appreciated.
Thanks a lot!
