My domain is: https://sciotowaterinc.com/
My hosting provider, if applicable, is: WebHostingHub.com
Hello Folks. I have everything as far as I know installed. The little lock in the corner says secure.
Does Let’s Encrypt always say self signed?
In removed the cert and it crashed my website. Please hang on until I get it back up.
Hi @fmwebs
checking your domain via sciotowaterinc.com - Make your website better - DNS, redirects, mixed content, certificates - there is the following result:
Domainname | Http-Status | redirect | Sec. | G |
• http://sciotowaterinc.com/ | ||||
198.46.82.197 | 301 | https://sciotowaterinc.com/ | 3.114 | A |
• http://www.sciotowaterinc.com/ | ||||
198.46.82.197 | 301 | https://www.sciotowaterinc.com/ | 2.053 | A |
• https://sciotowaterinc.com/ | ||||
198.46.82.197 | 200 | 1.510 | N | |
Certificate error: RemoteCertificateNameMismatch | ||||
• https://www.sciotowaterinc.com/ | ||||
198.46.82.197 | 200 | 1.243 | N | |
The certificate:
CN=*.webhostinghub.com, OU=COMODO SSL Wildcard, OU=Domain Control Validated
31.01.2017
24.02.2020
expires in 261 days
*.webhostinghub.com, webhostinghub.com - 2 entries
So both connections are insecure.
And there
Issuer | last 7 days | active | num Certs |
CN=COMODO ECC Domain Validation Secure Server CA 2, O=COMODO CA Limited, L=Salford, C=GB, ST=Greater Manchester | 0 | 0 | 37 |
are no Letsencrypt certificates, only older (expired) Comodo certificates.
No certificate -> no https.
