We want to use our servers BigBlueButton using Let’s Encrypt Certificates (https://github.com/bigbluebutton/bbb-install)
We get an error on Let’s Encrypt. We gave permissions on 80 And 443 Ports. But Our server was accessible only from Turkey IP addresses. I send screenshot. How to fix it?
