LetsEncrypt quota monitoring
Hello LetsEncrypt team,
I saw there was a thread about discussing the work of the API for monitoring LE quota usage Lets encrypt quota monitoring.
For my use case, I would like to know how many certificates have been used for my registered domain which has been shared across multiple users.
I would like to check if there is any update related to the work? Thanks :slight_smile:
I also tried https://crt.sh/. But looks like the result is not accurate.
crt.sh can have some trouble with keeping up.
That said, as an alternative, you could indeed try to set up your own certificate log crawler/monitor and only match your hostname. Crt.sh is open source: https://github.com/crtsh
crt.sh hasn't been that slow as of late, from what I've seen.
I made cert-search as a friendlier frontend which attempts to show your exact rate limits and time windows, but there are a couple of caveats which could only really be solved by a first party rate limit API.
