My domains is: https://crazyshop4all.gr/, https://bmwkings.gr/, https://dsteam.gr/, https://ksth-auto.gr/, http://autobodyfix.gr/
I ran this command: I've got limited
My hosting provider, if applicable, is: Myself, CyberPanel
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): CyberPanel
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): CyberPanel's Letsencrypt
So generally this form doesn't actually fit my support requirements and i am a company i can as well provide you my Certificate Incorporate, well the problem i've experienced is that:
I have made my websites ssl from another provider cause of this problem of limited, i did setup many times the control panel and in the process while the ssl certificates were issued many times i got limited, so in the e-mail domains: mail.crazyshop4all.gr, mail.bmwkings.gr, mail.dsteam.gr, mail.ksth-auto.gr, mail.autobodyfix.gr. Can i request extend of my limited usage so i can issue normally an ssl for those e-mail domains? We experience problems and my customers needs e-mail cause they are working with it with their customers, as you well understand the situation here is critical because we are business to business to client relationship and i really need your help here expanding or yet if it's possible unblock just to make those emails working again. Thank you very much for your time!
