Let's Encrypt SSL certificate and google recaptcha problem
we are using Let’s Encrypt SSL wildcard certificate and google recaptcha. recaptcha is giving error after let’s encrpyt ssl intergration. We got the error “Message: The underlying connection was closed: An unexpected error occurred on a receive. // System.ComponentModel.Win32Exception (0x80004005): The client and server cannot communicate, because they do not possess a common algorithm”
does anybody have an idea ?
Regards.
Can you please fill in the form provided and clarify your question? (Show us your domain name makes it much more easier to check)
Thank you
Trusted wildcard certificates aren't available yet. If you got a wildcard cert, you got it from the staging server, which means it's not signed by the genuine Let's Encrypt intermediate certificates and won't be trusted by browsers. That might be the cause of your problem, though if it is, the error message you got is misleading as it seems to indicate a ciphersuite configuration issue.
In any case, answering the questions as stevenzhu has requested should make things clearer. I've copied them again below. It might also help to clarify exactly where you're seeing that error message.
