Hey! (in advance sorry for the bad english) I had implemented recaptcha for forms in other servers with paid ssl and i got no problem. Now I’m implementing recaptcha in a domain with your ssl certificate and I always get error (I had created many versions to spot an error). The only conclusion I get is that it should be something wrong with the ssl. For applying the ssl to this domain I enable in the control panel from ipower because they have the defaul option and then making a .htaccess to redirect always to https.
Do you know if recaptcha is not compatible with let’s encrypt certificates? or Do you know something I could try?
Thank you for the time and help!!!
My domain is: https://www.afrumex.com/google_reCAPTCHA/prueba.html
I ran this command: submit
It produced this output: Please check the the captcha form2
My hosting provider, if applicable, is: ipower
